Hi guys,
I'm mounting my TV above a radiator. It's covered and is the only place the TV can go. It's hardly ever switched on so hopefully no worries there. The problems are:
1. For optimum viewing height I get the TV should be level with eyes. However mounting a TV there will look silly. Would you allow room for a soundbar or the likes in the future? I have an all front 5.1 system at the minute but if soundbars get better I may consolidate. How much gap should I leave between the TV and radiator for it? 20cm?
2. The radiator and cover isn't level, it's slightly off. I was going to put the TV level per my spirit level but I'm wondering if this is going to look weird with the radiator not being flat.
Any thoughts?
Cheers
Any thoughts?
Cheers
