Mounting TV to a wall
Caporegime
18 Oct 2002
London
Next project for the new house. We have an aging entry level (heavy) LG 55" and the wall in question is an internal plasterboard wall, so worried about mounting such a heavy thing to it. My brother-in-law gave me some dry wall anchors that are supposedly rated for heavy loads like TVs and has had no issues with his but posts I've seen on here and the Internet suggest it's a bad idea. We're keen to upgrade the TV (currently eyeing up his new Samsung The Frame) so chances are the replacement would be lighter but any recommendations for a mounting solution?
Next project for the new house. We have an aging entry level (heavy) LG 55" and the wall in question is an internal (non
-brick) wall, unsure if there are studs in. My brother-in-law gave me some dry wall anchors that are supposedly rated for heavy loads like TVs and has had no issues with his but posts I've seen on here and the Internet suggest it's a bad idea. We're keen to upgrade the TV (currently eyeing up his new Samsung The Frame) so chances are the replacement would be lighter but any recommendations for a mounting solution?
Depends what type of mount you want. The frame comes with its own mount for reference.
I use a SANUS VLT7 advanced tilt. Is a very sturdy mount and easy to install.
Thanks for the quick response, saw Sanus mentioned in another thread - will check out. But yeah basically looking for a metal mount with a little swivel or bracket to hang the TV along with the appropriate anchor for the screws/bracket.
Not entirely sure what you're asking about, but if it's about the fixings to the plasterboard wall I can fully recommend these: https://www.screwfix.com/p/gripit-tv-clam-plasterboard-fixings-25mm-x-205mm-4-pack/371hp
Using them for my 65" LG, they are solid. Also using them for a 43" in the bedroom with is on a swivel mount, so the TV is quite far away from the wall and no issues whatsoever.
Magnifique, thanks.
Magnifique, thanks.
Yeah, I deffo recommend the mount. It's super easy to adjust in any direction and take off and back on etc. Not the cheapest but feels premium in comparison to some others.
Now to determine how good The Frame is, very impressed with it so far though imagine there are better options for that price range if the art aspect isn't your thing.
Definitely getting cold feet again, our carpenter says he wouldn't risk it. Says any solution is as good/weak as the plasterboard. Current TV weighs 15Kg.
I saw a video recently where they tried to use a normal wall mount for the Frame TV and they couldnt as it comes with its own weird little mounts that dont seem to follow the normal convention.
