Hi
Have a samsung u360ru7100k that i want to wall mount on a stud wall.
spec says it weighs just under 14kg.
i want to mount it in the corner of my room so have got a full motion wall mount.
Where it is being positioned it will be mounted to the first stud in the wall, will a single stud take the weight or would it be worth putting a piece of wood between 2 studs and mounting to that?
Im leaning towards a piece of wood between 2 studs just for extra security.
Thanks,
Thanks,
