Mounting TV to wall.
15 Mar 2010
Bucks
Gonna have a bit of redecorating in the next few weeks and one of the plans is to stick the plasma (panny st30) on the wall.
anything i need to consider or can i just drill some holes, level it out and job done?
il be hiding cables with the centre speaker (tv wont be that high up) so thats not an isssue.
im a bit concerned that tvs manage to stay upright!
Good fixings, depends whether the wall is solid block wall or a stud partion?
I've just fitted my 40" Sammy to the bedroom wall with some M6 or M8 x 50mm coach screws, some will say it's over engineered, but I can rest easy knowing it won't fall off the wall.
Got the fixings from Toolstation about £1:15p for a bag.
Don't do the usual mistake and fix it to the wall at the height suitable for viewing when standing... I've seen so many where people have fixed the TV to the wall perfectly center, perfectly straight and didn't realise how high it was because they didn't bother to sit down.. lol
Always remember to sit down and get the height right.
eye level sitting down should be the middle height of the screen :cool:
We put ours into much the same sort of wall you're talking about. I picked up a big universal bracket from Amazon, this one, which is a pretty good deal at £39. It came with just about every kind of screw, bolt and rawlplug known to man. I ended up with 6 10cm bolts going into the brickwork. It's solid as a rock.
i did this :D
I love seeing people do this, it always makes me laugh!
Is it important to use wallplugs? every video on youtube doesnt but surely the brick work isnt that snug to the bolts?
how do you find out what type of wall it is? basically its the wall between me and my neighbour - looks pretty solid to me (but then walls do)
how old is the property? depending on age it could be a solid 300 - 600 mm solid stone wall (no problem), more recent 215 mm brick solid wall / brick /block cavity wall (ok again), timber stud, although not as common in england as it is in scotland, could cause a problem as the wall needs to maintain a 1hr fire resistance with no service penetrations (assuming you want to add an electric socket / hide the cables?
Sorry, yes, big old rawlplugs went in first. I had to drill over 10cm into the wall - I was scared I was gonna poke a hole into the neighbours' front room :D Of the 6 bolts, one ended up just spinning in the plug, so I guess that one didn't take, but the other 5 are solid and at least that 6th one is in there even if it's not entirely secure.
With the right type of screw (a masonry screw) then you can fix without a plug. But not all screws are masonry screws, and not all wall materials are suitable for masonry screws. I'll bet that many of those videos don't make a clear distinction.
This kind of stuff - putting up shelves and brackets - used to be common knowledge. But I guess with the internet/app age anything requiring physical labour and common sense is something of a challenge now ;)
Yes. The safe option is to use plugs. Simple.
Presuming that you found the wall to be solid...... Drill a couple of test holes. If the dust is red then you're drilling in to brick usually. If one hole is red and one is grey then you have brick but one hole hit the mortar between the bricks. If it is grey then you are drilling in to breeze block. If it seems like it's raining in doors then well done, you have found a concealed water pipe (see note 1). If there's a flash and all the lights and power went off and you're left wondering what that funny smell of burning is then you were lucky; you hit a mains cable in the wall but survived (see note2). If you wake up in an ambulance or in hospital then you were still pretty lucky but you'll have some scars to remember the incident by (note 2 again). If there's a big bang and you wake up strumming a harp then congratulations on finding a gas pipe or electrocuting yourself to death. (Don't bother reading any note 3, it's too late for that)
Both types of wall need plugs. Brick will be fine with your basic brown rawl plugs and 2" screws. I hung a bracket for a customer a couple of weeks ago on a brick outer wall with 5 screws as above. To test the strength I hung off the wall plate. I weight 15½ stone (98kg), so a 15kg telly will be perfectly secure as long as the plugs and screws are anchored securely.
Breeze block is not as solid as brick. You don't even need a drill. You can make holes in it with a screwdriver!! Fixing-wise you can go with Fischer SXR 08 TV Fixings which are a bigger longer plug and screw arrangement, or my favourite is chemical/resin anchors & studs.
Notes
  1. Turn off the water supply at the stopcock and call a plumber and your insurers. Total cost approx £150. Use a pipe & mains finder before drilling - Cost £7.99
  2. Call an electrician and your insurers. Total cost approx £150. Or use a pipe & mains finder before drilling - Cost £7.99
  3. Gas pipes shouldn't be buried in walls at the height where you'd mount a bracket, but with a pipe and mains finder for £7.99 it's better to be safe than sorry
Notes
im always amazed how many people dont know this type of thing (no offence OP :))
i take it many people's dads didnt make them work as a labourer with them when doing diy like i used to ;)
im looking forward to teaching my son some basics.
I didn't have a dad around to show me. I worked it out for myself. This was in an age before the internet (OMG!!). Anything that I was unsure of there were these things called books :D in a place called the library.
What surprises me most is the lengths a novice will go to when it comes to hanging a TV on the wall: Countless hours spent poring over the net, then the money spent on tools, the disruption in the house, the dust, the family arguments, the mess, not to mention the anxiety of "Did I do it right? Will it stay up?" and all for the final result of a slight iffy install with cables dangling down the wall like entrails ....lol If someone is to attempt DIY for the first time then be sensible, don't do it on the focal point of the living room.
Companies such as Martin Dawes and my own business can come out and do a professional job fully covered with public liability insurance. Specialists like myself go to the next level. We do a fully planned install where all the customers needs are discussed, and any issues such as poor aerial signal are sorted as part of the install.
fair play to you... ahh, libraries, i remember those.
all my dad did was teach me how to wire a plug etc. but it was useful.
my first DIY i did myself was ripping out old kitchen and installing a new one. that teaches you pretty much everything! :) in at the deep end!
