Mouse cursor is lagging - Logitech VX Nano
11 Oct 2011
UK
Hi all,
I have a Logitech VX Nano mouse, and the cursor seems to be occasionally lagging, this never used to happen near to when I first built my PC, has only started happening recently
The only things I have done since then really that may affect this are:
1. Buy a Logitech K800 (don't think that would affect it though)
2. Overclock my system to 4GHz (I can't remember whether or not this was happening before the overclock though)
I reinstalled setpoint when I got the keyboard so it shouldn't be that
Any ideas?
Hope you can help, :D
Little update
Remove the overclock and the problem still existed, so I overclocked it again
Then today I went to turn on the mouse ... and nothing! The mouse turned on, but wouldn't have any affect on the cursor
I tried my brothers VX Nano and his receiver and that worked fine
I then had to re-pair my receiver and mouse for some reason a couple of times using the logitech connection utility and it started working again now
I have not used it much today so I don't know whether or not the problem still exists as it only lags occasionally
I will keep you updated
Any ideas of anything else to try?
Thanks, :D
The mouse has been connecting to the PC fine recently, never has had any issues other than the one mentioned above which only happened once, but the lagging problem still exists
It was happening really badly yesterday (I was only web browsing, downloading some things and doing some college work), so I removed the overclock and went to bed
Today I have been using the PC (not overclocked) and it seems to be no where near as bad as last night, but it does still happen occasionally
Does anyone know what this might be?
Hope you can help and thanks in advance, :)
Bit off base but with my GTX 570 power settings set to adaptive as opposed to always on, when I scroll a webpage qute quick there can be some lag. This dissappears when I turn power to always on.
This lagging problem was happening again the other day really badly and my computer is currently running at standard speeds, not even overclocked
Really annoying as I don't know what's causing it
