Mouse for MMO's?
6 Aug 2009
Anyone any experiences with mice in MMO's ideally less than £60? Oh and okay for medium sized hands not a bunch of bananas :D
So far looked at Razer Deathadder, Logitech G500...
had my logitech for MX518 for a while now, and i can say im perfectly happy with it. the easy dpi increase and decrease buttons are great when going from a rts to fps to a mmo and includes great design and additional buttons not to mention great comfort.
thats what i'm currently using, just bought it recently and it hasnt really grown on me that much.... but mouses are all about prefrence.
Think i'll end up getting the RAT 9 expensive, but it looks funky but i think it'll be comfortable for me.
If you look up reviews for the Razer Naga around on various retailers you will see it has good reviews. If you raid or pvp competitively its a great mouse, although exchange rates have not helped it's price atm.
I have owned a MX518, which I upgraded to the G500.
I have replaced both with a Razer Deathadder. Amazing mouse, perfect size for me (medium sized).
Wholly recommend it.
Thanks I did have my eye on this one seems to have a lot of fans. My old MS mouse Intellimouse Explorer I think is starting to show its age!
Razer Naga is great for MMO's but only if you utilise the multi button thumb pad if your not a fan of having all those extra ones on the side you would not like that mouse. Ofcourse if you currently use a gaming keyboard with a lot of macro keys on it then you can switch some of these to the naga mouse and spread the work over 2 hands or the downside is in moments of pure frustration or something hit the wrong button on ur mouse and make mistakes ;p
The naga is also meant to be pretty handy in FPS by assigning the buttons to weapon switching ect but that is not something I have tried.
Yes I was thinking as I now have a G15 I don't need too many buttons on the mouse. Personally I think I would prefer have more actions controlled from the keyboard than the mouse...
