Basically I got eyefinity about three month's ago and every now and then I get this problem where out of the blue, my mouse cursor will be chopped up into small segments. It's finally driven me over the deep end and I really want to fix it now. I just powered up my computer and it's happened instantly this time on the right monitor.
Here's a bit of more in depth information on the problem. It can pretty much happen at any time and it only affects the cursor on a specific monitor. What I mean by this is the cursor will be chopped up lets say for this example on the right monitor then when I move it to the centre or the left monitor the cursor is perfectly fine. But when I move it back to the right monitor it's all chopped up.
It can happen to any monitor over the past three month's it's happened on all three monitors I mean as in the left or the centre or the right. although it wont happen and be the same on all three.
Lastly the only fix I know is to restart the computer enabling/disabling crossfire does nothing nor does changing the screen res or disconnecting the display.
-SKENG-
-SKENG-
