Evening,
Not sure if this is the right part of the forum.
Past few months or so, any game I play has noticeable input lag which is makes it unplayable especially Battlefield 4 which at the moment is the only FPS I play online.
It's bizarre as nothing has changed and all of sudden I have input lag that's too noticeable to play. Makes the mouse feel like it's in slow motion and I don't have complete 1:1 control.
About 6 months ago I realised that Windows 8.1 has "Enhance Pointer Precision" automatically enabled and turned that off and regained what felt to be 1:1 again prior to installing W8.1 from W7 but as above, last few months something has changed to cause the lag throughout a range of games offline and online.
The mouse is a Zowie EC2, all software (drivers, W8.1, firmware, BF4) is up to date.
Before I continue I'll list the spec of my computer.
Whenever I can I always run Vertical Sync as I can't deal with the screen tearing and particularly Battlefield 4 I'm running on low with no AA or HBAO, 100% Resolution at 2560x1440 59.5hz although Nvidia control panel says it's running at 60hz W8.1 won't allow me to save it as 60hz and returns to 59hz. Bug?
I understand that VS can cause slight input lag, but not this bad. To make sure it's not my mouse that's buggered I turned off VS in BF4 and hey presto no more lag and its fluid and responsive, not longer feels I'm using a brick for a mouse. I seriously considered if I've grown weary of FPS and its me that's the problem, but turning off VS confirmed its not me thankfully
To save you time I'll again list what I've already tried to resolve my problem.
I'm now wondering if it's my GTX770, considering I'm playing with lowest settings I'm curious to know it's a little out of its depth at 2560x1440? Or perhaps some bottleneck or something under performing to cause the input lag with VS on?
I don't render in the background or have a hundred applications running so I can't see myself that it's W8.1 problem.
Help and advice is greatly appreciated as I've come to a blank with this trying to figure out what's causing the extra input lag.
- Battlefield 4
- Borderlands 2
- Call of Duty - Advanced Warfare
- Call of Duty - Black Ops 2
- Far Cry 4
- Planetside 2
- i7 4770K @ 4.3Ghz w/ Speedstep
- Z87X-UD3H-CF
- C. Vengeance Pro 16GB 1600MHZ
- EVGA ACX GTX770 OC @ Stock
- Asus Xonar D2X
- Crucial M4 256GB
- 2x WD "Black" 2TB
- XFX "XXX" 750W
- Zowie E2C eVo @ 1000hz polling rate / 1150 dpi
- Steelseries QLK Mousemat
- Dell 27" Ultrasharp U2713HM via DisplayPort
- Windows 8.1 Pro 64-Bit (Genuine Licence)
- Windows Refresh (OS only)
- Battlefield repair, deafult settings and reinstall
- BF4 console commands (GameTime.MaxVariableFps 60, 61, 59.95, 59, 62)
- Nvidia driver clean install (347.52)
- Tested current mouse (Zowie EC2) on different PC and laptop
- New mouse (Zowie EC2-A) and spare gaming gigabyte mouse
- Nvidia Panel, enabled Triple Buffering, Maximum pre-rendered frame "3", Virtual Reality pre-rendered frames "Use the 3D application setting"
- MarkC Windows 7/8/8.1 Mouse Fix
