- 6 Oct 2012
- (do-or-die) Wye, Ashford, Kent, UK.
as above.
i have tried binfinite, metro 2033 redux, same thing.
soma works ok, but that is default to 60hz anyway regardless.
slow panning with the mouse is jerky, with the 360 controller, it is smooth.
i have applied this:
MarkC_Windows_10+8.x+7_MouseFix
it is a registry fix that has helped a lot of people out with silmilar issues.
it didn't work for me.
i have checked mouse options, and it is set at 6/11.
enhanced pointer precision is turned off.
i realise the other option is a new mouse and mat, as i don't have a brilliant quality mouse and mat. up to now i felt as though it was doing fine.
is there a way i can find out if my mouse is working how it should?
apologies if i seem confused, but the truth is, i am!
cheers!
baz
cheers!
baz
