Mouse / Keyboard cleaning
26 Feb 2004
Hampshire, England.
Hi guys,
As a general rule of thumb is, isopropyl alcohol (99.9%) okay to use on your mouse and keyboard to clean them? - I'd hate to degrade the plastic/rubber etc. I was considering getting some of the slightly weaker '%' wipes, as an alternative.
Plus, my hands are never usually dirty, I use hand San all the time, but I've noticed just lately that the rubber/plastic on some of my kit has started to feel a bit tacky... Why is that, is it a reaction or something?!
Thanks.
I have used IPA a few times to clean the rubber bit on my Logitech mouse without issue.
Certain rubber materials do tend to develop that sticky residue on them over time as they age.
I use soap and water on the key caps if they are removable.
IPA and general dusting on the keyboard itself.
Same with a mouse.. if the costmetics/non eletrical parts can be removed.
I wouldn't use IPA on rubber, it will probably break it down. Hand sanitiser is mostly alcohol as well. I usually just put a tiny bit of washing up liquid on a piece of kitchen roll, wett it under the tap and squeeze it out. Wipe everythign down and dry off with a clean piece.
If plastic/rubber is feeling tacky it could be breaking down and the oils are leeching out of it.
The rubber could be breaking down because of age or it could be a reaction between the alcohol in the hand sanitisers and the rubber.
