14 Jul 2013 at 11:49 #1 Pc-Gamer12 Pc-Gamer12 Associate Joined 10 Dec 2012 Posts 682 I currently have the roccat taito mouse mat and I just wondered is it possible to cut the mouse mat to shape my desk or will it just destroy it ? Thanks
14 Jul 2013 at 11:54 #2 WuMyster WuMyster Associate Joined 28 Feb 2012 Posts 1,851 Location London, UK I wouldn't advise cutting a cloth pad. The stitching on the sides keeps it from fraying and if you cut that off I'd expect to see fraying.
14 Jul 2013 at 12:03 #3 Pc-Gamer12 Pc-Gamer12 Associate OP Joined 10 Dec 2012 Posts 682 it doesnt look as if it has side stitching it looks glued ?
14 Jul 2013 at 12:07 #4 WuMyster WuMyster Associate Joined 28 Feb 2012 Posts 1,851 Location London, UK In that case I reckon it should be fine. I took a closer look on the image and as it more of a foam surface?
14 Jul 2013 at 12:37 #5 Pc-Gamer12 Pc-Gamer12 Associate OP Joined 10 Dec 2012 Posts 682 yes it is more of a foam surface
14 Jul 2013 at 13:18 #6 Pc-Gamer12 Pc-Gamer12 Associate OP Joined 10 Dec 2012 Posts 682 So it should be ok to cut ?
14 Jul 2013 at 13:32 #7 WuMyster WuMyster Associate Joined 28 Feb 2012 Posts 1,851 Location London, UK Yeah. If it's a foam it SHOULD be okay. Not 100% sure.
