Mouse movements not fluid
20 Oct 2002
UK
Hey,
I've been using my machine this morning for about an hour and the mouse has just started being jurky... it moves smoothly for about 2 seconds, then theres a 1 second pause, then after that it jumps to where it should be (if a fluid movement was happening) and cycles around on this loop
Any suggestions on what might be causing this? It has happened in the past and a reboot has sorted it but its a bit annoying!
I'm backing up important work and files before i do reboot in case something on the way to deaths door.
Thanks,
Have you checked the mouse itself, is the underside dirty, have any of the feet come off, if it's a ball type mouse, check/clean the ball plus rollers.
the ball itself i cleaned, i didnt unplug and plug back in... a reboot fixed it but i'll try that next time...
it feels, although i dont know how i can feel such things, like its Windows having a paddy tho
XP if that helps anyone, and its a Razor BoomSlang 2100 Mouse
