Mouse not working in MSI Click Bios
18 Jan 2011
South London
My mouse (Mionix Naos 5000) doesn't seem to want to work in the MSI Click Bios. It moves vertically but that's it. I really like the idea of the click bios and it's really frustrating that it doesn't work.
It also doesn't work with my Microsoft IntelliMouse.
Any ideas?
Well your mouse manufacturers needs to release drivers to enable your 2 mice to work in the BIOS. The motherboard manufacturers won't and can't do this.
Suggest contacting their respective technical depts?
This really is a bit annoying.
I've emailed my mouse manufacturer (Mionix) and they've said they'll look into it.
It's really rather strange, if I move the mouse up and down it does nothing. Moving it right moves the cursor down and left up.:confused:
Updated drivers won't help as they're not loaded until you get into Windows.
I have a Roccat Kone and this doesn't work in the MSI Click BIOS.
I just plug in an old Logitech MX518 and this works fine.
A firmware update for the mouse might help though. Else it'll be up to MSI to improve compatability with newer versions of their BIOS.
