mouse pad/surface
19 Oct 2009
I'm finding my ancient razer exactmat a little small for Pubg and after 9 years starting to wear a little smooth on my preferred control side. I'm struggling to find decent size hard surface pads, let alone larger ones.
Any suggestions?
My basket at Overclockers UK:
Total: £32.73 (includes shipping: £2.74)
I think the above is fairly popular with some users. Not sure if it's big enough for you.
Was literally just about to say this, I finally set it up yesterday and I love it, it's the first hard pad I've had since a very old Razer hardpad I had about 12 years ago.
It's insanely smooth and fast, my Razer Deathadder Elite with stock feet just glides across it, hopefully the Glorious Model O is even better when that finally releases.
Also, ignore the dimensions on OCUK. The correct ones are
  • Dimensions: 16x18 in / 406x457mm (GH-XL)
Hey guys, sorry to hijack thread but, what is the difference between the ghxl stealth and the gwxl, Just the logo or is there more to it, I'd like a thicker mat for comfort and play shooters. Cheers
