mouse pointer but no other screen images??
5 Feb 2009
N. Ireland
Hi all, I've run into a little problem and looking abit of help.
I tried to up gpu drivers to the latest. used the usual procedure, however once i installed the newest CCC drivers and restarted all appeared as normal but after about 30 seconds the screen would go blank. left it a while but the desktop didnt reappear so did a restart, into safe mode. couldnt remove the fresh CCC install so used windows recovery to jump back to just before i'd installed them, this again happened as normal but once the pc restart it BSOD'd.
Unfortunately i didn't catch the error message codes.
When the pc tried to restart again it went thru the normal gigabyte splash screen, then the windows loading screen, but when it switches to loat the password screen the screen goes blank and only the mose cursor appears.
I've reseated the gpu, and cleared cmos, tried the cable in both outputs and tried a different monitoe but still it happens. also happens this exact same way in safe mode.
so i'm afraid i'm at a loss. is it possible that the OS has some how become corrupted and needs a reinstall?
many thanks in advance
