Mouse problems on cold boot win 8.1
26 Jun 2010
Hartlepool
Hello, This only happens when my PC has been off for a good while, but when i boot up, the mouse is working but it is sort of off to one side, i can open a folder fine but if i try to move it by holding down the left mouse button and dragging it the folder gray's out, also inside the folder when i hover over a file, the highlight is about 2cm of to the left and 2 or 3 lines above the file i am trying to click on.
The only way i can get the mouse working properly is to do a restart. this happens every cold boot, and always works fine after a restart.
I have updated all drivers for mouse/keyboard/usb's but it still will not fix the problem.
Anyone had/getting similar problems?
This only started after installing win 8.1 Preview
