Mouse with no rubbersised coating ?
19 Feb 2007
Sol
At the moment I'm using a Corsair Scimitar Pro and while functionally it's excellent, The rubberised coating feels bloody horrible plus it makes cleaning it an impossibility, Are there any mice out there that have PBT shells or just rugged plastic ?
My budget is £100 or more if I have to, To get away from the cheap gross feeling of a rubber coating.
My Logitech G700S has no rubbery bits. Just a textured surface, but easily cleaned with a spray of your usual monitor screen cleaner type stuff.
From what I recall, the 900 was the same.
Rubberised coating is pretty much mandatory these days. Especially on gaming / expensive mice.
PBT? The last ones I used were the WMO and the MX518 (although rubberised sides).
Apart from that, The Ducky Secret IIRC was / is PBT (check for confirmation). Then there's the Finalmouse Ultralight Pro.
In general, white mice often have no coating.
No coating on my zowie fk1 but mine is years old and it could have changed. Not sure what plastic is used but there hasn't been any smoothing of it either.
