Mouse Won't Work!
2 Oct 2006
My logitech G5 WAS working, however i use setpoints drivers to bind things to the tilt wheel, and this feature wasn't working, i opened setpoint and it just had an "about" page. So i tried reinstalling setpoint, and now my mouse won't work, i've tried 7 different USB ports, and everytime i try to add the hardware manually it says "Windows cannot initialize the device driver for this hardware. (Code 37)". i try the solution it suggests, but this doesn't work :(
Try uninstalling the device driver for the device. Even beter, try using the restoring from a restore point from before you installed the driver.
When done, pop into the control panel and scan for hardware changes to reinstall or upgrade the driver.
Try the above in SAFE MODE.
