Mouse X/Y axis sensor alignment / Offset App?
11 Nov 2020
Hi All, I've been using a roccat kone pure desert Strike for years, on the the pure optical driver version 1.05 This driver support Sensor alignment and allows me to hold the mouse at a -20 degrees offset in order to remain comfortable in hand As far as I'm concerned this is an excellent feature however I've just purchased the pure Ultra due to its higher precision sensor and lighter weight (and also because my previous Mouse is getting a little bit manky to be honest) Only to find that it requires the Swarm driver and and sensor alignment is no longer available + non compatible with the older v1.05 pure optical drivers )-8
So what I'm looking for is a third-party application that will do this job as roccat have not got back to me in regards to this issue & I literally can't draw a straight horizontal line anymore.
looking around the web I've not found much in regards to this which I find surprising however there was one link to a app which didn't seem to be compatible with Windows 10
long story short I was just wondering if anybody could help me out at all?
Thanks in advance for your time.
