Move from DFI775 to775ASROCK
10 Dec 2005
UK
I want to move from DFI LANPARTY 875P-T SOCKET 775 to ASROCK SKT-775 4COREDUAL-VSTA S/L 1066FSB, is it worth swapping over?
Using 650LGA775 3.4 GHz, 2Mb L2 cache, 800Mhz FSB, memory 3200 1GB ram.GeForce 7800 GS AGP.
Well, i don't know about your current motherboard, but the Asrock, supports DDr2 as well, so it is a good upgrade path type motherboard. Also, it has a PCI-E slot, and both IDE/SATA2...perfect motherboard for upgrading systems piece by piece
Affraid the SATA is only SATA 150 not SATAII 300 and the PCI-e gfx slot is only a x4 one, but it is a cheap way to get a C2D system.
Best overclocking is using a 800fsb cpu.
