move to water/oher bits
Permabanned
18 Apr 2006
14 miles from OcUK
move to water/other bits
im considering a move to water cooling
i fancy a new motherboard as well, with a veiw to moving to quad when the prices drop in july
also my aging antec p160 is crammed so i fancy a bigger case:
roduct Name Qty Price Line Total
Gigabyte GA_965P_DS3P (Socket 775) PCI-Express DDR2 Motherboard £74.99
(£88.11) £74.99
(£88.11)
Lian-Li PC V2000B PLUS Black Aluminium Full-Tower (No PSU) £137.99
(£162.14) £137.99
(£162.14)
Zalman Anti-Corrosion Coolant - Blue (500ml) £10.99
(£12.91) £10.99
(£12.91)
Swiftech MCR120-QP-B 120mm Radiator £14.99
(£17.61) £14.99
(£17.61)
Swiftech MCW30 Chipset Waterblock £15.99
(£18.79) £15.99
(£18.79)
Masterkleer 7/16" Tubing - 1m £1.49
(£1.75) £1.49
(£1.75)
Danger Den DDC-12V Pump £43.99
(£51.69) £43.99
(£51.69)
DangerDen Single Bay Resevoir £18.99
(£22.31) £18.99
(£22.31)
DangerDen TDX Block (LGA775 Processors) £30.99
(£36.41) £30.99
(£36.41) Sub Total : £350.41 Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £10.95 VAT is being charged at 17.5% VAT : £63.24 Total : £424.60
what are your opinions on my chosen parts?
is there anything ive forgoten
are they all compatible and would that chipset block do the north bridge on the ds3p ?
thanks in advance
stinka
edit: changed to coolant to add to my distilled water :)
Looks 100% to me, but im no water cooling expert. Good choice of case aswell :)
Did you not look into the DS4? Ive heard it overclocks that little bit better.
All looks great to me. As said above though, look into the DS4. Also, I heard that the 'Non-Conductive Solution' is just a gimmick, and that you'd be better off using distilled water.
Amen brutha, thou should only use the finest holy distilled water in ones high tech rig.
modded my spec im gonna stick with my evga 680i
will the swiftech mcw30 fit my northbridge, im thinking this is more universall so when i replace motherboard it will fit my new chipset maybe
is a single 120mm rad good enough or should i go for a bigger rad seing as ill have so much room in the v2000 +, and futer proofness for adding a gpu loop
Your basket
Product Name Qty Price Line Total
(£51.69) £43.99
(£51.69)
(£22.31) £18.99
(£22.31)
Lian-Li PC V2000 PLUS Silver Aluminium Full-Tower (No PSU) £129.99
(£152.74) £129.99
(£152.74)
(£12.91) £10.99
(£12.91)
(£17.61) £14.99
(£17.61)
(£1.75) £1.49
(£1.75)
(£18.79) £15.99
(£18.79)
(£36.41) £30.99
(£36.41) Sub Total : £267.42 Shipping cost assumes delivery to UK Mainland with:
(This can be changed during checkout) Shipping : £10.95 VAT is being charged at 17.5% VAT : £48.71 Total : £327.08
any more comments on chosen components apreciated
thanks
