Moved mobo CPU into new case - high fan speed
25 Oct 2002
Bedfordshire, UK
I've just moved my mobo, CPU, RAM to a new case. I've reinstalled Windows as I have a new drive as well. When the PC boots up the CPU fan speed is very high at around 2200 rpm and I can't work out how to slow it down.
Things I've done:
  1. Reset CMOS
  2. Checked CPU temp - at 25C!
  3. Check CPU fan speed setting was set to Normal. Changed it to Silent and it's still fast.
Have I broken something when I moved it? What could it be?
Mobo is GA-Z68MA-D2H-B3 https://www.gigabyte.com/Motherboard/GA-Z68MA-D2H-B3-rev-10#ov
Did you clean the fan on the cooler when you moved it - if so how?
*There's a chance that your fan is damaged.
Your motherboard has PWM fan header - so have done a quick selection. Your present fan spins up to 2000/2200RPM.
All would do the job - selected fans similar to your present fan's max speed (didn't know you temps/clocked) - all PWM and varying budget/performance and relative silence.
My basket at Overclockers UK:
EDIT: Compare Acoustical Noise (dB) : airflow ratio if that is important.
See above:
Didn't notice your edit:
It's weird though because the fan spins up quietly and then when the Windows logo appears after POST it spins up to full speed.
Did Windows update recently/at the same time (Windows 10)?
Do you have any gigabyte utilities installed - e.g. Easy tune 6?
Could still be fan damage - but i would uninstall Easy Tune (if installed) or any other third party windows fan controlling software to be sure they're not causing an issue.
It's a fresh install of Windows 10. The fan spins up to high speed just before windows starts to boot after POST. I'm wondering if it's more BIOS related than a problem with the fan? I only say that because it does spin quietly during POST.
So no third party fan control software?
Could be - as the CMOS reset didn't help you could try updating or, if up to date, re-flashing the BIOS.
However, when you vacuumed the fan - did it spin freely for a considerable amount of time?
No. Fresh install of Windows, I haven't installed anything yet, it spins up fast before Windows boots anyway.
Makes me nervous but I'll give it a go as a last resort.
Not really, I just vacuumed the fins and the front for a few seconds, it didn't spin at all I don't think.
Use the Q Flash utility and a freshly formatted Fat 32 pen drive with latest BIOS file - perfectly safe. (*Just don't use the Windows environment to do it.)
If the fan didn't spin then you haven't damaged it - but still could have become faulty just from being moved. Can't be ruled out i'm afraid just because of symptom.
Cheapest option is to flash the BIOS.
Hit <END> at start of post to enter Q-Flash. Use the prepped pen drive and follow on screen prompts to direct it to the file. (Remember: freshly formatted Fat 32 pen drive and only the BIOS file installed).
OK, I flashed it and it's still the same. Maybe I'll just try a new fan then, although I am sceptical that's the issue. Thanks for the help!
Inclined to agree - but needs ruling out. Although, very coincidental that problems started after reseat.
No worries - here's hoping a fan replacement works...
It worked! Thanks for the help. I went for the Akasa and it's nice and quiet and spinning at low speed.
