- 30 Dec 2003
Apologies in advanced regarding the little information I can provide here. I've recently moved home (hence the moving of the PC) and I've had little time to look into this problem... It's still a cause of a headache, though - This was the last problem I expected I'd be spending time on when moving!
I do not know details about the spec at this time (it is not the - old - spec in sig) however I'm more interested in what cause it's likely this could be.
Anyway, the PC has been moved carefully at all times. Upon turning the PC on I got a beep pattern and the machine did not POST. I do not know how many beeps or what they mean. I took the side off of the case to see if anything was obvious (there was not), and then plugged it back in again and it booted. I got a BIOS message saying something along the lines of the PC had failed to boot multiple times and that 'optimal defaults' would be used.
Windows then booted and complained about the Ethernet controller, which has always worked fine. It said it could not install the hardware successfully and no trying to get it to find a fix online helped.
No worries, I thought, this PC uses Wi-Fi so I disabled the on-board LAN in the BIOS. Booted the PC the error message went away (of course). I then tried to use the PC and found it would automatically reboot. This happened at random time intervals - Sometimes it'd be okay for only a few minutes others for twenty.
Any idea what this could be? It's always been fine until our move and I can only imagine that the two things (ethernet controlled malfunctioning and rebooting) are related but I do not know the cause and whether it is a hardware or software issue. I know I've not been able to supply any specifics but I'm hoping this may be possible to diagnose, in part, with the symptoms alone.
Thanks.
Thanks.
