Am running 2 x 290 in crossfire which I am replacing with 0ne EVGA 1070 FTW. (may get a second later but given monitor runs @ 3440x1440 unlikely I will be going sli until a monitor upgrade)
The 290's are watercooled as will the 1070 when installed. (full loop res/pump to triple roof rad > cpu (5820k) > first gpy > 2nd Gpu > single rad > res/pump).
Have been running amd for a good few years so the change to NVidia is a bit of an experiment - I assume that the procedure should be :-
1. Using driver cleaner remove ALL amd software and remove msi afterburner with ancillary programs
2. Take out 290's
3. install 1070
4. Download (from evga) the most recent drivers - and what else? (anything I should deliberately avoid?)
Advice appreciated - am I missing something or including when I should not ?
2. Take out 290's
3. install 1070
