Moving a game between drives on Ubisoft Connect?
7 Dec 2002
UK
Anyone know how to do this? I'm trying to move Assasins Creed: Valhalla, i can't find any options or settings for this?
If you move the install folder manually, you can then open the Ubisoft app, go to the game you moved, go to Properties, then there'll be a button like "Find Folder" or something. You then just point it to the folder where you've moved the game and it should verify all the files.
Edit: Just to add, don't move files etc while the Ubisoft app is open.
Thank you, i'll give that a go!
