Hello,
I have recently moved into a new house which I had wired with ethernet throughout.
I didn't think the location of the patch panel through very well though and am now seriously considering moving it.
The current scenario is all walls are dot n dab plasterboarding.
Their are currently 20 runs of cat 6 going into one of the bedrooms (converted to office) they exit the wall through a standard double backbox and are covered with a brush plate, location approx 18inches from the floor.
I cannot just pull new wires as they are not run in conduit.
If I can get wire behind the dot n dab straight up into the attic I can relocate the patch panel very easily. I was going to have a go at fishing behind the plasterboard from the atticspace.
what I would like to do is connect the existing wires to the proposed new wires somehow AND hide that in the wall and plaster over it (or at worst hide the wires beind a blanking plate)
Making a single neat channel up the wall just to feed the wires through is a consideration, the new location is easy to sort out once I have wiring into the attic.
How would be best to tackle this ?
