Moving from Evolv ATX TG to Meshify C a good move?
22 Oct 2012
The Moon
Hi,
I've been using the Evolv ATX TG for some time and love its aesthetic qualities. However, the airflow is poor, especially when mounting hardware in the top sliding bracket. I currently have an NH-D15S but could move to a water cooling solution.
Should I move from my current case to an airflow optimised one like the Meshify C or look at a way of improving my current chassis?
Would the thermal effect be less when using an air cooler over water cooling?
Cheers.
Do you mean custom WC or AIO? There is no problem if you use one rad in the front or air cooling. Only if you use 1 rad on top or 2 rads (top and front).
I wouldn't change to meshify as build quality is way worse, disappointing if you compare to Evolv.
