Moving from Vista 32bit to 64bit
26 Aug 2005
Slough, Berkshire
Hi
Well.... Ive successfully installed Vista 32bit OEM on a new partition on my hard drive complimenting my previous XP Pro install in dual boot setup. But Im thinking of removing my Vista 32bit and replacing it with 64bit. Me having a modern PC probably means that I wont have problems obtaining drivers and the future option of using 4gb of memory may appeal to me.
Firstly, my Vista install has not been activated yet. Is it safe to sell this on, or does the fact that I entered my key during install prevent me to do so?
Secondly, how do I go about with this? Do I simply format the Vista partition and install Vista 64bit? Will I keep the XP Pro in dual boot options or do I have to do something to keep them?
Cheers in advance.
