Moving public folder store 2003 with replication
8 Jun 2006
Hertfordshire
Gents
The SAN the data is on has become unreliable and we need to move them over to our EMC box, reading online you just repoint and store dismounts, moves and I can then remount, we have replication between two public folder stores is there any hidden gems that anyone knows of?
Many thanks
Mart
:confused::confused::confused:
cant you just remove the old one and change the default public folder store for the mailbox stores?
Sorry I'm not sure I follow what you mean by this? I do have 2 one on the new location and the other on the sick location, I just want to move the second one over, sorry if I missing something your pointing out :(
Are they replicas of the same folders or hosting different folders?
If they're replicas, the data is already on the new location and you just need to remove the old one
iMacMart, you need to check the data on the 'good' array is the primary PF source (not assigned as replicas) and commit the logs after dismounting, the rest of the procedure is correct.
When you dismount the PF IS make a duplicate copy of it and run eseutil.exe against it so ensure it's in a consistent state (logs comitted) before copying it over.
Iirc the command is C:\eseutil.exe /mh <path to edb file>
Once it's all committed, it should be ok with moving over. In my experience anything can go wrong with Exchange 2003 IS', hence making a copy of the data after dismounting (so you can remount in the event of a failure). It will give you time to troubleshoot the problems before repeating the procedure.
Move not remove? Or point to the new SAN location
Replication was setup for redundancy
If its a replica, the data is already at the other location. So the old one just needs to be removed, surely?
You just change the public folder store property against the mailbox stores to the correct location and remove the old one (after removing the replica references against the folders). Unless I'm missing something about how its set up..
