Moving to a bigger case?
11 Mar 2013
Hi folks
Black Friday got me a 295x2 which is currently shoehorned into my little 350D case.
Space is a bit tight and if I'm being honest I'll probably need to replace the case with something bigger. I have a Phanteks TC14 fan in there too and the gap between my gpu and cooler is only a couple of mm. Mounting the rad for the gpu has been a total mission too due to my motherboard getting in the way.
I was going to replace the air cooler with a liquid cooler to free up some space so I could find a different place to mount the rad for the GPU but I also want to keep noise to a minimum too (had a h100 previously and it kept things cool but it was noisy)
So I'm thinking about a bigger case which is a shame as I love the design of the 350D.
I'm torn between the NZXT 440 and something like a 750D unless there are others that are worth a look? I prefer subtle cases to over the top plastic ones (hence the 350D)
I see OCUK do a pre water cooled version of the 750D, does anyone have one? Or would I be better off say putting together a kit of my own? I might end up adding the GPU into a loop too but not sure as yet.
Thanks folks
