Moving up from a 7850
9 Dec 2007
Hants
Hooray another upgrade thread! :D
Currently I'm running a Sapphire 7850 2Gb and it's starting to show it's age a little. Running something like Cities: Skylines the GPU is always north of 80% load and I'd like the option to try some of the newer FPS like TC: Division.
Looking at the Sapphire R9 Nitro 380 4096MB GDDR5 which is within budget:
https://www.overclockers.co.uk/sapp...rd-with-backplate-11242-13-20g-gx-374-sp.html
Any thoughts if that would be a worthwhile upgrade? Google suggests the R9 380 should be about 80% faster?
Rest of my system:
i7-2600k @ 4.4
16Gb DDR3-1600
P8P67-M Pro (PCIe 2.0)
Samsung 830 SSD
OCZ ZT 750W
Running 2 displays @ 1920x1200
Any thoughts/suggestions?
Cheers :)
It's a cracking card, especially at £150 as it was when I bought one, I also came from a Sapphire 7850 2GB. Not sure it's what I'd buy with your set up though, I 'd probably save a little more and buy a 390.
