Moving watercooled system
7 Sep 2011
Stafford, UK
I was all set to build my new system but then i thought to watercool it, the only problem i have is i move around a lot proberely 12+ times a year and would be moving my computer every time, would a custom loop still be feasable or would i have to bleed the system every time i stop in a location as the journeys can be long (10 hours) and i dont fancy having to keep do this.
Thanks :D
Depends on the connections you use. If you use compression fittings and you've run a sufficient leak test then it should be fine
Keep the case box and packing and use that when you travel.
