So i'll be moving in about two weeks, only up north same country but bit of a pickle what I should do with the fluid.
The PC will be strapped into the seat next to me in the car
so I'm inclined to just take the GPU out as you normally would and leave it but should I drain the fluid?
And on another note if I should drain the fluid is it okay to reuse once my baby is in her new home or should I buy fresh?
Thanks
so I'm inclined to just take the GPU out as you normally would and leave it but should I drain the fluid? And on another note if I should drain the fluid is it okay to reuse once my baby is in her new home or should I buy fresh?
Thanks
