Moza AB9 FFB Base - missing button presses
14 May 2009
I'm having an issue where FS2020 and 2024 are randomly missing trim inputs (assigned buttons). I am using the joystick from my Thrustmeter HOTAS but I believe they are meant to be compatible. I was also using the base via a USB but but the problem persisted when I connected the base directly to a USB port on the laptop. I see the same effect with Window's USB Game Controller Widget to.
Has anyone else seen this? Got any ideas to rectify it (apart from buy the official joystick handle ;))
Cheers
Cheers
When you assigned the trim buttons in FS, did you assign them against the Moza base?
Yes, they work sometimes but not others. But it's failing outside of FS as the Windows USB Game Controllers Widget is unreliable as well. So IMHO it's more a more fundamental issue.
Forgot to say, it all used to work and I think a recent software/firmware update might be the cause.
Sounds like you might have a USB port issue with your PC. Do you experience issues with other devices plugged into the port?
Have you tried the AB9 with another PC?
I haven't worked out how to roll back the firmware, I also submitted a support request early last week that hasn't had a reply.
Luckily for me a friend has lent me his Moza MH9 flight stick so I can see if it's the base/software or my Thurstmaster HOTAS to blame! When he dropped it over both handles seemed to be working fine.
