- 30 Jan 2009
- East Sussex
Have just modded my thermaltake mozart ( seemed like a good idea )
I used 2 mozart cases to complete the build +
5 x 120mm white bitfenix fans
2 x 120mm white led bitfenix fans
1 x NZXT CB-LED10-WT 12x White LED Sleeve
2 x Alphacool NexXxoS Pro II 240 rads
13mm / 10mm tygon tubing clear
1 x XSPC Acrylic Dual 5.25" Reservoir
1 x Laing D5 Vario Pump
1 x EK Supreme LTX CPU Waterblock
2 x EK Water Blocks EK-FC6970 - EN (Nickel)
4 x 3/8" G1/4 - High Flow Style - Shiny Silver- Compression Fitting
4 x 3/8" G1/4 - FatBoy Style - Shiny Silver - Barb Fitting
2 x 90 Degree Rotary Compression
1 x Phobya Variable VGA Connector
4 x white bitfenix 6 pin pci-e extention
1 x white bitfenix 8 pin eps extention
1 x white bitfenix 24 pin extention ( waiting to be back in stock )
1 x NZXT 4 SATA 90 degree data to 4 SATA data cable - White
2 x bitfenix alchemy molex to 3pin x3 fan adaptor 12V 20cm - White
1 x bitfenix alchemy molex to sata data extention white
and the rest in my sig below
Some original mozart pics
