Following on from this old thread which was dug up, I decided to do something along the same lines using the latest version of the LAME MP3 encoder.
[download down for now, back later] contains two files, a BIN file and a CUE file. You need to extract both to the same folder and use a program like ImgBurn to burn the image to disc. Just select the CUE file and the program should do the rest.
The CD contains five copies of a Manic Street Preachers song. One is directly ripped from the CD using EAC. The other four are conversions of this rip into various variable MP3 bitrates, using LAME 3.98.2.
The challenge is to put them in order of bitrate used (and if you can, to guess at the bitrates themselves.)
Similar rules apply as with the previous thread - if you post your results, quote them and write in the same colour as the background so you don't influence other people.
Have fun
Have fun
