mp3 oddities
Permabanned
14 Jun 2004
anyone know why some mp3s report the wrong track length and/or wont allow you to skip through them with the slider bar, but will play start to finish if u leave them ??
eg winamp is reporting the correct length, but wont allow me to skip through, it just starts at the beginning again, the bitrate is also varying. wmp6.4 reports incorrect length(double what it should be), plays right through, allows you to skip with the slider bar and reports 198kbps bitrate.
You should re encode the mp3's again they probably havent been encoded correctly. I have had similar problems with video files that have been bodged!
