- 7 Mar 2005
- LU7
I commute into work a few times a week and I like to listen to music on the walk to the station and on the train. I wear hearing aids and have recently bought a cool little gadget that I can use to listen to music without having to fit cables directly to my hearing aids. It uses a loop cable around my neck that my hearing aids can receive audio through wirelessly. Currently I have the device plugged into a Fiio M3K using a cable but I would like to use the Bluetooth function of the device so I only have that hanging off my neck and not the Fiio M3K as well which is just more cables.
Is there a reasonably priced MP3 player that has Bluetooth, so the hearing aid gadget can connect to it, but that also can take large capacity SD cards? I have a 400GB SD card so the MP3 player would need to accommodate SD cards of a similar capacity, perhaps up to 512GB or even 1TB. By reasonably priced I mean no more than a few hundred. I have found some other Fiio portable DACs but they are either £800-900 or well over £1k so this is out of the equation.
If there isn't I was thinking of getting a decent Android smartphone and just using that as an MP3 player.
