MP3 Tagging
31 Jan 2007
Hi,
I have a whole folder full of mp3 files which is a audiobook spit up into mp3s the correct size of an audio cd. I wish to tag them all correctly but I tried MP£ Tag and that seems to only allow me to change the tags for one at a time. How can I set some tags for 1 track like the author and then that to be copied across all tracks and then the title and trackno which will ahve dynamic number parts which need to be changed for each track?
Neil
Tagscanner works well for this, but then so does MP3 Tag for me. Just select all of the tracks you want to retag for artist or album. You'll have to set the track title individually unless you have the tracks' filenames correctly sorted out - in which case MP3 Tag has a Filenam-Tag button that will redo the tags based on the filename.
