MP3 Tags
12 Jun 2005
Hi there,
I am after a free program that will download the song information tags based on maybe the name of the song and the artist....
I use iTunes by the way, it that means anything
Thanks....
[edit]
Been looking in this thread (Click here), but I am unsure of which to go for, anyone used any of them
[edit]
I was hoping for something that would download the tags automatically from the song name and artist. I would like it to download things like Genre, Album, Year, Track No out of No...etc..
I use "ID3-TagIT v3" which has this option,. Will search online databases based on file names of the mp3s and then tag them accordingly :) Very handy. Can also do file name > ID3 tag which is good if you already have the files named properly
I was wondering if there is anyway to do a batch tag download....so i can select all of my tracks and it download the information based on the track name and artist?
Is this possible?
Thanks...
I use Tag&Rename for music tagging:
Incredibly useful for getting tags from filenames, and vice versa. Shareware though unfortunately.
If you use it in conjunction with what Baddass suggested, all your tagging problems will be solved :)
Hi there,
I like the program suggested above, it doesn't do what I want it to do, but I am starting to believe that is impossible. The program above makes it quite easy to do it manually though.
Thanks...
[edit]
It just looks truely awful and it sometimes a pain to work :/
