'most' xvids and divx's on the net will play ok in a standalone player, if its really jerky then you might need to use mpeg modifier to unpack the stream.. you just click open, select avi, untick 'packed' and click save avi, takes about 3 mins
i think you can also use fourcc to trickt he player into thinking its a real divx file to force it to play ok
wait for more replies..
the mpeg modifier did the trick for me on LOADS of files..
