MPEG -> FLV
27 Dec 2005
Bristol
I'm trying, desperately, to convert a number of MPEG (720p) video files to FLV for web use. I've tried numerous programs including Allock and SUPER (based on ffmpeg) and both are absolutely rubbish - bad quality or ridiculous file size.
We would just use embedded YouTube but as they automatically block/restrict video with copyrighted audio it's just not possible.
The question is, how do YouTube get 720p videos to be of such a good quality and such a low file size? They've obviously invested millions into this but where can I start to try and match it?
The adobe media encoder that comes with CS4 would do that fine, just means you need CS4 ;) Im not sure about any other programs though.
Using AME now, but still playing with settings to try and get the best filesize:quality ratio. At the moment I'm converting at 900x506, 25fps (H.264), AAC 128/44 @ VBR 1-1.5mbps (2 pass).
What filesize per minute is usually deemed acceptable for web use?
20mb a minute is what mine have turned out at with PAL res, 25fps and it gets very good results.
I see you hire out the Z7, how have you found this camera with low light? I have the option to use that next year along with the EX3 and HVX200.
That seems quite high? I've managed to get 720x404 to about 7mb a minute and the results are pretty good. I guess it depends how much you want to risk it for your viewers - the trouble with self-hosting rather than using YouTube is you can't as easily integrate the option to switch to a lower res/file size.
Very good :). We film in low light all the time (wedding first dance usually) and the results are always good. You can see a few examples at the end of our showreel (
) or on our non-live site (http://v2.idoweddingfilms.co.uk/example-wedding-videos/). For your info this topic was in relation to the videos on that page :).
That's good going, what settings were you using? I haven't played around with them myself because the clips I upload to vimeo are between 2 and 8 minutes so I haven't had a need to make them smaller.
That's great, the low lights capabilities look really good, and the groom flipping over his bride was awesome :cool:
Why don't you upload it to youtube and let them convert it all, then just download the flv :p using orbit downloader+grabit or equivalent?
A lot of the videos have the audio blocked due to copyright (which is the original problem) so any downloaded FLVs would be audio-less.
I've decided to upload two of every video and have the user choose normal or high quality before the video loads.
