MPEG4 Conversion?
18 Oct 2002
My folks recently bought an Archos 504 portable media centre. They're trying to open an MPEG4 file on it and it will not open. Apparently, Archos haven't released a codec yet for it, and want to charge when they decide to release it for a download (15 bloody quid!). When they've just spent hundreds on the unit, I'm loathed to give the company more money to allow it to play files a media centre should play by default.
Would anyone know of a good program to convert an MPEG4 file to a different file type without loosing the quality of the original file? I've tried Allok MPEG converter, but whatever file type I convert it to appears to be corrupt.
Any help on this would be awesome. I've never had to convert a file before so the easier the program to use, the better (also any tips!).
Winavi is a good converter but not free. Dvd2svcd is a free converter but you need an encoder to run it which isnt free. There are some free converters out there if you search long enough. If you go to socketaplus forum and contact me there i can help you out more.
