Mr Sheen Dustgrabber.
24 Sep 2005
Stoke
Is it ok to use one of these to clean dust from my TFT screen? Currently have a pack of lemon fresh refils sitting here and i'm not sure what to do. :)
If that "Mr Sheen Dustgrabber" is designed for dusting the house, I wouldn't recommend this as it's probably too harsh for any LCD panel coating.
Take a look here:
http://forums.overclockers.co.uk/showpost.php?p=7251564&postcount=1089
I posted this in the 20WGX2 thread and it's generally applicable for any type of the LCD panel coating (standard, AR or glossy).
Hmm also remember to clean your glasses first if you wear them... because last time I cleaned my screen I thought there was a massive smear across the screen. I kept on cleaning and cleaning the monitor and the mark wouldn't go, so I then looked at my glasses and I found a smear on it!!
BTW certain glasses cleaners are good for monitors, the one I use is awesome and it leaves no marks.
