MS Access problem
24 Aug 2006
say i input data into an input form, then move to the next record, is there a way to populate the fields with the data that I entered in the previous record (without having to copy and paste each field across)?
e.g. form
write a macro?
or is there a command built in?
any other ideas?
isnt it possible to have the database in rows and column's stylee (if you get what i mean, the default view of ms access) and then just copy ala paste a whole row and several columns into a new row?
good idea thx
