MS Access SQL Word Frequency
18 Oct 2002
Hi
I'm trying to build a search system using MS ACCESS (and classic asp) which returns the most relevant results at the top.
I have a memo field that stores a large description. Is it possible to calculate how many times a string appears in this description?
E.g. If the word 'advisor' appears in the description 10 times, I need it to return the number 10.
Thanks for your help.
Use a string search to see if the string occurs, then do the same again starting from after the first occurrence. Repeat until found no more.
Not used Access for years but the following would work in SQL Server so should be fine in access
DECLARE @dataToSearchThrough VARCHAR(2000)
DECLARE @strToSearchFor VARCHAR(2000)
SET @dataToSearchThrough = 'I like to harvest harvest, I like to harvest'
SET @strToSearchFor = 'harvest'
SELECT (LEN(@dataToSearchThrough) - LEN(REPLACE(@dataToSearchThrough, @strToSearchFor, '')))/LEN(@strToSearchFor) AS NumTimesWordAppears
This works fine when executing the query in MS Access.
However, when i try and execute the the stored query using my classic ASP script, it errors.
Code:
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
[Microsoft][ODBC Microsoft Access Driver] Undefined function 'Replace' in expression.
Basically, JET doesn't support the Replace function.
Do you know if its possible to get this working at all?
My code to execute the query is below:
Code:
query = "EXECUTE q_storedQuery '" & parameterVariable & "'"
set RS = Server.CreateObject ("ADODB.Recordset")
RS.Open query, DataConnVac, adOpenKeyset, adLockOptimistic
Not sure perhaps you could use ODBC. I don't use access. In SQL Server you can create stored procedures so perhaps that's an option.
Might be worth searching on stackoverflow and google to see if anyone else has had this problem.
