MS Flight Simulator on Xbox?
3 May 2012
Wetherspoons
Hi,
I know little about consoles, my 60 something year old father is thinking about getting an Xbox to play the most recent Microsoft Flight Simulator game.
Will it run okay on an Xbox?
Assuming you can get joysticks etc that you can connect?
Yeah it’s fine, though I would get the series x to play it, it’s a very demanding game. I would check out the official ms flight sim forum.
And yes you can use mouse and joystick, I use a turtle beach velocity one flight stick.
ms2024 is coming next year as well, not sure when though.
Yeah its fine on Xbox Series X, it doesn't look as good as on PC the performance is very good.
There are plenty of joysticks that are compatible, I've got an Airbus Stick/Throttle which is PC/Xbox compatible and works really well.
