Right, you are probably thinking that this is just another thread... but mine is slightly different - I promise.
I own Vista Ultimate Retail. I do my fair bit of overclocking, so sometimes have to boot into windows with an unstable PC. This has sometimes broken my windows install, which is not always pleasant, given the time it takes to do a fresh install.
Soooo, I'm planning on setting up 2 partitions on my RAID0 array. The first will play host to my main O/S. What I want to do on the second partition is place a test O/S which I will boot from when running stability tests.
Summarily, I have the O/S on one 'machine' only, the same hard drive etc, but two different installs - one used only as a test environment (and is still quicker than imaging). I cannot run both at the same time, obviously.
So, any problems with this?
Thanks in advance!
smids.
Thanks in advance!
smids.
