MS MCE settings
Suspended
17 Mar 2006
How do I create custom layouts in Media Center?
I want "Play DVD-Video" menu which'll play the inserted DVD-Video disc
Then I want "Watch videos" With a option of playing from a folder, (but this is what is missing) playing off a DVD-R also. I can enter in folders to search for, but not drives.
Also when I put the system into standby, and switch it back on the username/password screen pops up. I've left it blank but you still have to press OK to login. Is there any way of getting login processto go straight back into MC?
edit managed to work it out, you need autoplay enabled- so as you insert the disc with the .avi files it then appears in my videos section. One problem though is that I get a line where the OSD disappears.
right also sorted out re-logging in problem from standby, there's a setting in power /control panel (don't ask for password for coming out of standby)
