MS office 2003
24 May 2006
North Wales
I have a (legit) copy of office 2003 running on an XP laptop. Whenever I open any office part (word, excel, etc) it tries to install something but fails (as the office install CD is not in the drive, but even if it is present nothing installs). This also happens if I try to open a document directly but word (or whatever) is not open.
If I click cancel (to stop the install) word, excel, etc open up normal. I never get an error message or crashes, all parts of office appear to be present, so I am wonderring: how do I stop office from trying to install something else every time?
I installed office onto an XP desktop (then a vista desktop) with no problems, so I don't know what to do. Any suggstions?
Fluffy
Sounds like it trying to finish the installation off and you don't have the necessary write/modify permissions to do so. Check your application event log, is there anything in there (error wise) that relates to ms office? Does it ask for a specific file, is there any kind of error message?
Fluffy
Try reinstall maybe? Also, make sure you're not on a standard (non admin) account
Have/Do you remember ever running Disk Cleanup before? Most of the time, Office setup keeps files on C: to repair itself, and they can be removed when running Disk Cleanup.
Try Detect And Repair which is found in the Help menu of Word Excel etc.
Failing that, it does sound like preferably a complete uninstall and reinstall.
